Old 12-19-2017, 02:52 PM   #1
Dave Young
Dave Young's Avatar
Default Newbie needs help ...
Nice day today ... thought it a good opportunity to start the A and run it around a bit.
Went through the start up drill ... gas on, spark retarded, etc. etc. ... Nothing happened! No response at all to stepping on the starter button. Tried again, several times, same (non) result.
During this process, I had turned the ignition key on and off several times and suddenly realized that I couldn't remember which positions of the key were 'on' and 'off'. Then I discovered that I could remove the key from the switch in either position. The horrible thought suddenly occurred to me that I may have left the ignition 'on' the last time I used the car. A week ago. (who knew you could pull the key while in the 'on' position)
If that is the case ... what might I have done? Dead battery? burned up points, condenser, I really have no idea. This is where your help comes in.
First, I don't know for sure that's what happened and I assume that you knowledgeable guys would know what order to start checking things to find out what happened. If you can give me some ideas what to start looking for, I'd appreciate it. Keep it simple if you can, I'm no mechanic.
Dave
Dave Young is offline   Reply With Quote
Old 12-19-2017, 02:59 PM   #2
JDupuis
JDupuis's Avatar
Default Re: Newbie needs help ...
The switch turned to the right (clockwise) is "on"
Turn left is "off"
Will the lights turn on?
Step on brake pedal, does amp guage show discharge?
If "no", recharge battery.
Remember, if 6 volt, "POS" is ground.
Jeff
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
Old 12-19-2017, 03:17 PM   #3
Dave Young
Dave Young's Avatar
Thanks, JDupuis ... Just checked. No lights, no amp discharge from brake pedal.
I'll assume, then, that I've got a dead battery. But if it was caused by my leaving the ignition on, will it have caused additional damage beyond the dead battery? I'm suspecting that it was the ignition switch because I can't see any reason for a good battery to suddenly die without warning. Is a dead battery beyond the help of a trickle charger? (So much to learn, so little time)
Old 12-19-2017, 03:19 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Put a 4 to 6 amp charger on the battery, connected to the starter switch and ground. Make sure polarity is correct, and the stock Model A is NEGATIVE at the switch. Leave it on the battery for 24 hours, since it sounds like you may have completely drained the battery.
You may have fried the coil, but charge the battery first to find out.
Old 12-19-2017, 03:22 PM   #5
Y-Blockhead
Y-Blockhead's Avatar
Dave, not trying to be a Smart A$$ but do you have a Master Shut off switch? I have been known to shut off the Master Switch, then forget about it and go into panic mode... I went so far to attempt to jump start my car before I realized I had no ground.
Old 12-19-2017, 03:31 PM   #6
Dave Young
Dave Young's Avatar
Blockhead ... No, no master shut off switch. Wish I did though. I'll tackle that project in the Spring.
Dave
Old 12-19-2017, 08:19 PM   #7
sethkestenbaum
sethkestenbaum's Avatar
David,
Many a Model A (and garage) has been lost due to electrical fires that could have been avoided with a master shut off. I installed one years ago (there is a great post on fordbarn showing how to wire one into your floorboards so you can reach it as you get in/out of your car). Part of my "shut off ritual" is to hit the horn before I leave the car. With the battery shut off switched off, I get no honk and the chances of an electrical fire are eliminated. Turning the key "off" doesn't shut all the electric off to the car.... so watch out
As Tom noted, you may just need to charge your battery. If you don't have one, now is a great time to get a trickle charger. They are cheap and will help you keep the battery charged in the future (in the event that you don't drive enough for your generator to recharge the battery fully).
I hope this helps.
Seth
Seth Kestenbaum
www.oldcarroadtrip.com
sethkestenbaum is offline   Reply With Quote
Old 12-19-2017, 08:33 PM   #8
1955cj5
1955cj5's Avatar
There have been several threads on battery cut-out switches as Seth mentions....Here is one..
https://www.fordbarn.com/forum/showthread.php?t=3654
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 12-19-2017, 08:51 PM   #9
Big hammer
Connecting the charge leads to the starter switch and the frame is quick and easy,
But when was the last time WE have serviced our batteries? Good time when our battery needs charged to check the battery level, connections, clean the battery, etc, so going through the floor and do some maintenance :-)
get a bigger hammer tap done
Old 12-20-2017, 12:46 AM   #10
700rpm
700rpm's Avatar
Loosen your battery caps during charging. Don't position yourself directly over the battery at
any
time during the charge. After charging, disconnect your charger, then replace your caps.
Ray Horton, Portland, OR
Old 12-20-2017, 05:32 AM   #11
john charlton
john charlton's Avatar
Sadly over the years I too have drained the battery by leaving the ignition on, this mainly happened when I had left it running and it had stopped or ran out of gas . I now have got into the habit of checking the ampmeter when I exit the car mainly to see if my Chinese generater cutout has not stuck closed so I know from that I have switched off . You can be lucky when the engine stopped the points are open but normally they are closed . The coils seem fairly rugged as I have never burnt one out (yet !!!)
John in misty cold winter morning Suffolk County England .
john charlton is offline   Reply With Quote
Old 12-20-2017, 06:48 AM   #12
NCRebel
NCRebel's Avatar
I keep a note that states, "turn the gas off!" in the car. That reminds me to do my starting ritual in reverse. The only way I imagine learning the system by rote is driving more often.
If we don't make mistakes, we're not learning new things.
NCRebel is offline   Reply With Quote
Old 12-20-2017, 11:40 AM   #13
1930artdeco
1930artdeco's Avatar
To me at least there are two reasons: dead batt or bad ground. I have gotten in the habit of just disconnecting the batt. at the end of trips.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 12-20-2017, 01:21 PM   #14
nhusa
nhusa's Avatar
I found it hard to get to the battery to disconnect it so I put a switch and fuse in the wire from the starter to the dash panel. That way I always disconnect everything except for the starter.
nhusa is offline   Reply With Quote
Old 12-20-2017, 03:25 PM   #15
Dave Young
Dave Young's Avatar
Well, here we go again ... I figured I'd take the battery out, run it down to my local
service garage and have them check it out. If it's still good, charge it up, if it isn't, get me a replacement.
Got the floorboard up, took off the battery cables, removed the hold down bracket ...
then discovered that there's no way I can lift the battery out with my old arthritic fingers.
Now I'm sure I'm not the first guy to run into this ... There must be a device that clamps onto the top rim of the battery that will then enable it to be lifted out. If so, what's it called and where can I get one?
Sorry to be such a pain, but eventually I'll be able to answer questions instead of always asking them.
Dave
Old 12-20-2017, 03:33 PM   #16
1955cj5
1955cj5's Avatar
I'm sure there are more than just these...
A couple are sorta like the old ice block carriers!
https://www.oreillyauto.com/shop/bat...niversal-19572
Old 12-20-2017, 03:40 PM   #17
sethkestenbaum
Some rope or a few old belts can be used to wrap the battery and help start the lift.
You may need to shift the batter around to get the rope/belt under it to start things off.....as an aside, I've found that the neighbor's kids are also a great resource for lifting car parts.
Seth Kestenbaum
Old 12-20-2017, 04:09 PM   #18
Dave Young
Dave Young's Avatar
Thanks, 1955. I looked in all the model A catalogs I have, but nobody had anything like these. On your recommendation, I've already ordered the Lisle Carrier for about $20.00
And Seth, I tried using a couple of old neckties to use as a lift, but couldn't get the battery up enough to get them underneath. And no neighbor's kids in our retirement community. Good idea though.
Dave
Old 12-20-2017, 04:10 PM   #19
MickeyT
Send a message via MSN to MickeyT Send a message via Yahoo to MickeyT
I use two large pliers ( they are called water pump pliers ) and grab a post with each.
I've also used this tool and it works very well.
https://www.amazon.com/dp/B00FDXIGWS...a-306575760231
MickeyT is offline   Reply With Quote
Old 12-20-2017, 04:16 PM   #20
sethkestenbaum
depending on the condition of the battery holder, you might be able to work them under the battery from the bottom. It sounds like a good use for some old ties. Have you figured out how to set your distributor using a cumberbun?
Seth Kestenbaum
