#1 |
Hello,
I found and original windsheild - I think - is there a way to see the difference between an original and a reproduction ? |
#2 |
None of the reproductions come with the four small holes on each side for the original side curtain studs. there's also a subtle difference in the cross section with the reproductions being slightly flatter.
#3 |
I only found the windsheild frame not a complete windsheild, anything there that differs reproduction and original ?
thank you som much |
#4 |
I was only referring to the frame itself, not the add-ons that make up a complete windshield.
#5 |
Here's a pic of a crusty old original I have. You can see the four holes on each vertical side for the side curtain attachments that David speaks of.
#6 |
#7 |
Just the shape of the frame is easy to see. Repops are flat. Look at the picture Chris posted it has more shape. Does anyone make one just like originals?
A man should do what he thinks best! "The Duke" |
#8 |
thank you so much, mine seems to be a reproduction from 1976, since the glass is stamped with that year.
