12-12-2017, 03:27 PM | #1 |
51 Shoe box brakes
Any one have the disc brake kit from Shoe box central on the front of there car . I just about have every thing new on my brake job even a dual master cylinder still not stoping good drums have been cut,new brake shoes with softer lining,new wheel cylinders & flex hoses almost all new metal brake lines
Thank you for any help on this |
12-12-2017, 04:00 PM | #2 |
Re: 51 Shoe box brakes
Chris at SBC may be able to help you out. You have manual dic brakes so they will not feel like power. Do you have a proportioning valve? Is the pedal low or does it feel hard but the car is not stopping? Did the master cylinder come with the brake kit?
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
12-12-2017, 04:57 PM | #3 |
Are you saying that you still have drum brakes on the front?
12-12-2017, 05:57 PM | #4 |
Are you confident that all air has been bled from the brake system?
Can you lock up any wheels? If you can have an outside observer look at the car when doing this so you can understand which wheel or set of wheels aren't helping you to stop. If you can't lock up any wheel(s) get a brake pressure gauge kit ($50) to learn the pressure at each corner. This is a 2 man job as you will place the gauge into the bleeding screw and observe while someone presses the brake pedal. This is a diagnostic which will tell you if you have adequate pressure at each wheel to stop the car. Video of procedure |
12-12-2017, 06:19 PM | #5 |
Did you arc the shoes to the drums??
Paul in CT |
12-12-2017, 07:37 PM | #6 |
12-12-2017, 08:00 PM | #7 |
I have to second what Tubman said, the all rebuilt STOCK drum brakes in my '51 performs very well. At one time I assumed I was going to front discs as I had on some other vintage cars, but never did on the '51.
I went, I saw, I bought the T shirt 51 Ford Deluxe Tudor 32 Ford roadster 39 Mercury Towncar |
