Old 12-01-2017, 03:57 PM   #1
Tom Cavallaro
Tom Cavallaro's Avatar
Default Model A Charging Conditions
Just wondering if I can keep the battery up under normal daylight driving conditions. At the cutout, I'm at 7.2 volts, at the battery I've got 6.9 volts, and at the Amp meter I'm reading 6.5 amps. Assuming the amp meter is accurate. Does this sound like all is fairly good or should I raise it up? Without some input, I'm afraid to cook the battery.
Thanks in advance.
Tom
I work very hard to avoid all and any mistakes. I thought I made a mistake once, but I was wrong.
Tom Cavallaro is offline   Reply With Quote
