Old 11-29-2017, 10:30 PM   #1
Gunmetal blue2
Gunmetal blue2's Avatar
Default Sun visor 29 CCPU
I will have to recover the sun visor and need to know what is the best way to bend the tabs that hold two stripes of metal on. Do you heat to bend the tabs or just bend them. Don't want them tabs to brake off. Thank you in advance.
Gunmetal blue2 is offline   Reply With Quote
Old 11-30-2017, 12:48 AM   #2
Slowplane
Slowplane's Avatar
Default Re: Sun visor 29 CCPU
I recently did this same repair. Heat the tabs to cherry red before attempting to do any bending. Proceed slowly.
______________
Nothing Short of Right is Right
Slowplane is offline   Reply With Quote
Old 11-30-2017, 09:24 AM   #3
Rex Perry
Any trick to bending the tabs down after the cover is installed?
Rex Perry is offline   Reply With Quote
Old 11-30-2017, 09:36 AM   #4
wrndln
What Rex stated is my concern also. I can't see how you could heat the tabs once the covering is installed, without damaging the covering. It would be nice to hear from people that have replace the covering on there CCPU visor concerning rebending the tabs.
Rusty Nelson
Old 11-30-2017, 09:47 AM   #5
Slowplane
Slowplane's Avatar
Not really. after I'd heated the tabs and let them cool, the metal remained "pliable" (like new metal).The fellow that taught me this suggested that the heat "rearranges" the metal, making it pliable once again. I was cautious to only bend them ONCE after installing the strips over them. it all worked out better than expected, and my visor frame was a good piece to start with.
______________
Old 11-30-2017, 04:29 PM   #6
Slowplane
Slowplane's Avatar
The initial heating will rejuvenate? the metal. Don't do anything while its hot!
Put the cover on, put the strip over the tabs, then bend the tabs down. Do all this at room temp...
I also cut some pieces of plywood to fit the 3 sections of the visor, both sides, and after cementing the cover together, weighted them together, and it looks good(like it was stitched.
______________
Old 11-30-2017, 10:33 PM   #7
Gunmetal blue2
Thank you all my truck is in restore mode. I have it in about a thousand pieces. My retirment project lol
Old 11-30-2017, 11:55 PM   #8
700rpm
700rpm's Avatar
If you think you will have more time after retirement, you are going to surprised.
Ray Horton, Portland, OR
Old 12-01-2017, 11:21 AM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Ray,
MY DAYS seems 22 hours LOOOONG--The Dog just SLEEPS!!! I DO spend a lot of time COOKIN'---Don't you feel PITIFUL for me?
Bro Bill
"THE ASSISTANT GURU OF STUFF"
Old 12-01-2017, 11:47 AM   #10
700rpm
700rpm's Avatar
Originally Posted by BILL WILLIAMSON View Post
Ray,
Bro Bill
Sounds like you have found a good answer, Bill.
Old 12-01-2017, 12:14 PM   #11
wrndln
I received a nice email from Marco about how to bend up the tabs holding the metal plates on the visor without breaking them later and rebending them once new material is installed. He said to use a very small tip on an acetylene torch and heat only the area where the bend is before trying to straighten the tab while still very hot. The heat softens the area where the bend is, annealing the metal so when reinstalling the new cover, the tabs can be bend down cold without much chance of the tabs breaking.
Rusty Nelson
Old 12-02-2017, 01:35 PM   #12
Gunmetal blue2
Thank you Rusty that was more what I was looking for.
Old 12-02-2017, 03:15 PM   #13
jimalabam
jimalabam's Avatar
Gunmetal blue 2: I agree with some of the others, my retirement days are entirely too short, and yes Bill, my dog sleeps near my desk while I try to get everything done. I almost daily as that old question: How did I do all this when I was working, BUT I have an answer - I move slower...
jimalabam is offline   Reply With Quote
Old 12-02-2017, 03:33 PM   #14
1955cj5
1955cj5's Avatar
Lots of helpful pictures here...
http://www.abarnyard.com/temp/82-a/
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
