Old 11-21-2017, 10:55 AM   #1
kimeccles
kimeccles's Avatar
Default 1930 headlight bar mounting
Is there supposed to be a thin rubber gasket where the headlight bar bolts to the front fenders? Same question with the rear taillight mount. Thanks
kimeccles is offline   Reply With Quote
Old 11-21-2017, 11:05 AM   #2
Bob C
Default Re: 1930 headlight bar mounting
No and No.
Bob
Old 11-21-2017, 11:17 AM   #3
kimeccles
kimeccles's Avatar
Thanks
Old 11-21-2017, 06:21 PM   #4
J Franklin
J Franklin's Avatar
If you want to use the pads, make sure you get a good grounded connection under the bolts and nuts.
Old 11-21-2017, 06:49 PM   #5
kimeccles
kimeccles's Avatar
Thanks. I am going original, everywhere I possibly can, within budget, time, and what is left of my sanity.
Old 11-21-2017, 08:21 PM   #6
J Franklin
J Franklin's Avatar
While not original they do make a nice finished appearance and helps to keep the paint undamaged.
Old 11-21-2017, 08:53 PM   #7
kimeccles
kimeccles's Avatar
Yes, I am a bit concerned about the $5,000 paint.
You have a valid point.
Kim
Old 11-21-2017, 09:32 PM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Some things on Model As were mounted with a thick paper "gasket".
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 11-22-2017, 12:33 PM   #9
duke36
The vendors have both types, no lip and with lip. Follow post #4 to get a good ground for the lights.
duke36 is offline   Reply With Quote
