Old 12-17-2010, 06:20 PM   #1
Coupe35
Default Hot air manifolds and new firewall
WOW, these hot air heaters put out the heat. This is my first and only experience with one and when I installed it, I was not expecting much heat. But on a 30 degree day it will run you out of the car. And the engine temp did not get over 150 degrees. My question is. I would like to install a new firewall insulator, but since they are made out of plastic, I’m wondering if the area around the vent will melt. The vent gets so hot, you cannot touch it. For you guys that have a hot air heater and new firewall what’s been your experience?
Coupe35 is offline   Reply With Quote
Old 12-17-2010, 07:44 PM   #2
Fe26
Default Re: Hot air manifolds and new firewall
Is this a new setup you're using? I'm thinking of heating my coupe and am wondering which way to go. Thanks.
Fe26 is offline   Reply With Quote
Old 12-17-2010, 08:19 PM   #3
Coupe35
No, it's an original setup. I do not know of anybody reproducing them today. At times, You see them on ebay.
Old 12-20-2010, 06:31 PM   #4
Fe26
Thanks Coupe 35, one I was watched just finished on ebay, passed in, reserve not met.
Old 12-21-2010, 09:40 PM   #5
Lincoln
Enjoyed looking at your hot air heater pics. Try www.hotair4fords.com for the firewall insulator. They make a fiberglass replacement hose for the original Ford heaters, and they might fit your heater.
Lincoln.
Lincoln is offline   Reply With Quote
Old 01-01-2011, 09:05 PM   #6
eddieakers
I have a hearter just like yours but I am missing both the sheet metal end for the manifold could you take some photos of both ends and e-mail them to me. [email protected]
Thanks Eddie
eddieakers is offline   Reply With Quote
