#1 |
![]() City:
Mebane
State:
NC
Price:
$24,500
For sale is my original steel 1927 T Roadster . It is powered by a modified 1929 Model A engine.
*Original 1927 T body finished in Washington Blue. *Custom built frame *1929 Model A engine with pressurized oiling , insert bearings, counterbalanced crank, fully balanced rotating assembly, aftermarket rods, Stipe B cam, aluminum Winfield cylinder head, V8 oil pump ,dual 9 Super 7 carbs (stromberg reproductions), lightened flywheel , V8 clutch , FSI electronic distributor, external oil filter , oil cooler ,thermostat, alternator , tube header, Griffin aluminum radiator, V8 water pump. *Engine built by James Rogers of Dream Works . *5 speed manual transmission *Model A banjo rear with 3.54 gears. *Front disc brakes. *Rear 1946 drum brakes. *Dual master cylinder. *Kelsey Hayes wire wheels. *Leather interior with a custom made seat , plenty of room for me @ 6ft 200lbs. *Original but modified Model A brake and clutch pedal assembly. *Tonneau cover , with center zipper. A nice car that is a pleasure to drive , with overdrive in 5th gear and the 3.54 rear it will run 70mph @ 2000 rpm’s . Send a PM if you are interested or email me at [email protected] |
