Old 11-08-2017, 09:55 AM   #1
barkleydave
barkleydave's Avatar
Default Swaging hubs
Sure this has been covered.
Is a 20 ton press enough to swage lug bolts to hubs and drums?
Seems like it would take closer to 30 Ton to get it done right?
Thanks
barkleydave is offline   Reply With Quote
Old 11-08-2017, 10:22 AM   #2
John
John's Avatar
Default Re: Swaging hubs
No, a 20 ton Chinese press will not do the job. It takes an honest 22-23 tons to swage the lugs so use at least a 30 ton press.
John is offline   Reply With Quote
Old 11-08-2017, 10:37 AM   #3
lindy williams
Times 2
lindy williams is offline   Reply With Quote
Old 11-08-2017, 10:52 AM   #4
barkleydave
Thanks that is what I thought.
Old 11-08-2017, 01:39 PM   #5
Gastrap
Gastrap's Avatar
I ended up right at 24 on mine when they were tight.
Gastrap is offline   Reply With Quote
Old 11-08-2017, 04:11 PM   #6
leo
leo's Avatar
Consider sending your drum/s to Bert's in Colorado. Steve does this all the time and the turnaround is fast. If you have not done this before it requires a talented approach and the correct tools or you will damage the drum. After the job is done the drum needs to be checked to be sure it is still true.
leo is offline   Reply With Quote
