Old 10-26-2017, 11:16 AM   #1
Topcot
Default Oil leak around spark plugs
I have a ‘50 8BA flathead and am noticing some oil around 2 of the spark plugs. I am using an Autolite 216 plug. Should this have a flat or tapered gasket? What might cause this? Engine rebuilt about 1000 miles ago. Has Offy heads.
Topcot is offline   Reply With Quote
Old 10-26-2017, 11:37 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Oil leak around spark plugs
Generally this happens with loose plugs.
Should have a flat crush washer.
Old 10-26-2017, 12:08 PM   #3
Topcot
Do you know what torque setting should be used? Thanks.
Old 10-26-2017, 12:55 PM   #4
Ball and Chain
Ball and Chain's Avatar
18-22 lbs with gasket into aluminum
Throttle Benders
Est. 1949
Ball and Chain is offline   Reply With Quote
