Everlasting Turn Signal question
I just installed turn signals on my '29 Coupe and I used an Everlasting turn signal switch. 6v pos ground system. Everything is working fine as far as the signals are concerned, lights light and blinkers blink etc....
My problem is the when everything is turned off, engine not running, there is a small light in the turn signal unit that is always on. It flashes when its supposed to, but is always on.
Do I have the incoming power wired wrong? Do I need to put in a cut off switch? Faulty turn signal switch? Should I just kill the bulb and not worry about it?
Thanks, Greg
