10-06-2017, 04:57 PM | #1 |
Orignial 1934 mesurment needed
looking for the measurement from the axle or the cross member to the centre fender joiner ,I get 14" but suspect it should be 14,1/2 or 15"Thanks any one ,Ted
10-06-2017, 05:15 PM | #2 |
Re: Orignial 1934 mesurment needed
Given the way you're measuring in the picture you posted, I measured 14 1/4 inches from cross member to joiner.
13 1/2 inches from axle to joiner....
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 10-06-2017 at 09:38 PM. |
10-06-2017, 05:29 PM | #3 |
My 34 Fordor measures 13-1/2" from the web of the axle to the front of the joiner--
In haste, I had written crossmember instead of axle the first time--Sorry Old age setting in-------- Last edited by 34fordy; 10-06-2017 at 07:07 PM. Reason: screw-up |
10-07-2017, 09:41 AM | #4 |
I'm getting 14.5" from cross member to front of joiner piece on my Fordor.
10-07-2017, 09:55 AM | #5 |
Well, guess that pins it down to the nearest inch!
10-07-2017, 10:41 AM | #6 |
10-07-2017, 10:59 AM | #7 |
Web of axle to front of joiner on a 33 - 13 15/16 " .
Web of axle to front of joiner on a 34 - 14 1/16" . Much straighter line than crossmember to joiner . Plenty areas for this dimension to wander !!!!!! |
10-07-2017, 11:43 AM | #8 |
It is 14-1/2 from the web (inside) of the axle to the front of the joiner on my 33.
Jim S. |
10-07-2017, 01:52 PM | #9 |
OK thanks ,The grills often don't fit that well and I think its because of a bend about were the horn mounts ,14-1/2 is about were I thought it should be ,Ted
