Old 12-13-2010, 03:46 PM   #1
dave m
Default removing windshield glass ?
Any tips on how to remove glass from frame & still keep intact for pattern----35 coupe-----thanks
dave m is offline   Reply With Quote
Old 12-13-2010, 04:59 PM   #2
19Fordy
19Fordy's Avatar
Default Re: removing windshield glass ?
I did it by applying plenty of dish washing liguid under the outside lip of the rubber gasket rubber while at the same time pushing glass and gasket inward as I slid a bondo spreader betweeen the car body and the gasket.. Here's more info. ://www.streetrodderweb.com/tech/0705sr_installing_a_v_butt_windshield/photo_04.html
Old 12-13-2010, 07:48 PM   #3
oldbugger
oldbugger's Avatar
Dave, I am assuming the screws are out. I had good luck laying a block of wood on the glass then tapping with hammer, working around the frame trying to make even progress. Take your time it should come loose.
oldbugger is offline   Reply With Quote
Old 12-13-2010, 09:53 PM   #4
Coupe35
My problem was getting the 2 halfs of the windshield frame apart, which I could not. I was going to replace the glass but decided not too. The only way to get the frame apart for me would be to heat the area with a torch, but that would damaged the chrome. I try the block of wood and tapping it with a hammer but no luck.
Coupe35 is offline   Reply With Quote
Old 12-13-2010, 10:07 PM   #5
Lawson Cox
Lawson Cox's Avatar
Try a heat gun instead of a torch.
Old 12-13-2010, 11:59 PM   #6
dave m
wont the heat damage the safety glass -blistering the sandwich middle layer
