#1 |
![]() City:
Stockton Springs
State:
Maine
Price:
$15,000
This is a very solid and rust free Model A Ford roadster with an originally installed rumbleseat. The car was a barn find from Iowa and still retains the original interior and character of a true survivor. The top was replaced in 2012 and new side curtains were custom made for her. When I had the motor rebuilt, everything was done right with new Babbitt bearings poured by George King in Connecticut and new components used throughout - if you have had any of this kind of work done you will know the expense involved...
Here is a list of work that was done: - All brakes rebuilt - All original shock absorbers rebuilt - New wheel seals front & rear - New king pins & bushings - New aluminum fan (originals were prone to cracking & failure with ugly results) - New motor mount springs & pads - Fuel system cleaned, shut-off and sediment bulb rebuilt as well as the gas gage and original Zenith carburetor - Engine rebuild including new Babbitt bearings, crank ground .020 under, re-babbitted rods, bored .060 over with new pistons, rings, and wrist pins, new stainless steel valves springs & keepers, new manifold & head studs, oil pump rebuilt, new oil pump drive gearing added, new timing gear. - Transmission rebuilt including new sealed front and main shaft bearings, sealed cluster gear shaft, sealed reverse gear shaft, new cluster bearings, new clutch disk, and a new throw out bearing. The car is sold with a valid Maine State warranty title. I'm located around 13 miles north of Belfast in Stockton Springs - Mark Wetherbee (207)323-8994 Please leave a message if you call, I don't always hear the phone and I usually don't answer unknown numbers... Thanks for looking, Mark Last edited by Mark W.; 10-04-2017 at 07:28 AM. |
#2 |
sorry about the cell-phone pictures being up-side-down
#3 |
This one is still av
#4 |
Bump
#5 |
With recent interest I thought I would bump it up before the snow flies and strands it in my Barn till spring.
#6 |
Thank you |
