Old 09-25-2017, 05:22 PM   #1
hammerless-12
hammerless-12's Avatar
Default Model T bands linings
I'm putting bands in a friend's 1923 model T. It has the removable bands, meaning, in theory you don't have to remove the "hogshead" to replace the band linings. But Ive never liked pulling the band's up and out of the inspection cover. When he brought the car to my place he had two "new old stock" sets of Scandinavian band linings with him for me to install in his car. Each of the new band linings are marked "For all Ford cars 1926-1927, T and TT". His thought was to use two narrow bands out of one set, then use one of the narrow bands out of the other set. Having never dealt with this before, I agreed to do the job useing his bands under the assumption the NOS band linings would work just fine. I pulled the hogshead off and found a very well worn set of linings, particularly the low speed band. As I prepared to rivet the NOS linings onto the band's I compared the lenght of each band lining, they where right on. However the NOS lining is considerably thicker. These things are thicker than any band lining I've seen for the model T. My question is this, will these linings work in this car? The NOS linings look very nice and, if I where to guess, they probably date back to the 1960s or 70s. They also came with, what I believe, steel rivets.
Any help or input is greatly appreciated.
Thank you.
hammerless-12 is offline   Reply With Quote
