Old 12-12-2010, 02:46 PM   #1
josh1331
Default Leakless water pump&6blade fan
OK, HAVING ENG.REDONE WANT TO PUT ON LEAKLESS WATER PUMP AND 6 BLADE FAN. QUESTION: WHERE IS BEST PLACE TO BUY THESE QUALITY ITEMS FRIENDS?
jOSH
josh1331 is offline   Reply With Quote
Old 12-13-2010, 12:55 AM   #2
Dusty
Dusty's Avatar
Default Re: Leakless water pump&6blade fan
Snyder's
Dusty is offline   Reply With Quote
Old 12-13-2010, 03:03 AM   #3
pdora
pdora's Avatar
Mike's
Peter A. Dora -- Rutledge, GA (AE4XH)
pdora is offline   Reply With Quote
Old 12-13-2010, 07:02 AM   #4
sturgis 39
Burts
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED
Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread.
sturgis 39 is offline   Reply With Quote
Old 12-13-2010, 07:35 AM   #5
Brian SATX
Brian SATX's Avatar
Bratton's Hey I figured we need them all listed here.
Brian SATX
Brian SATX is offline   Reply With Quote
Old 12-16-2010, 04:26 AM   #6
sturgis 39
I did too. LOL
Old 12-13-2010, 07:55 AM   #7
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
OK Josh, a couple of questions for you. What makes a good leakless water pump in your eyes? Do you want one that us an original housing that has been modified to be leakless, --or do you want a unit that is a brand new housing, new stainless shaft, and all new parts?
Also, why a 6 blade fan? Why not an original style 2 blade repro in aluminum, --or why not a 4-blade steel like has been the mainstay for decades and decades? Or, putting it a different way, if a 2 blade fan can adequately keep a "warmed over" banger motor cool in even the hottest climates, do you lose anything by going with more blades? (i.e.: more noise, more parasitic drag, less airflow at faster speeds, etc.)?? I think you do.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 12-16-2010, 08:34 AM   #8
MrTube
MrTube's Avatar
One of the main reasons I wanted to pull the 4 blade fan off of our A was noise.
Sometimes you just need a little less fan.
Since we're on the topic of cooling, How effective is the fan shroud I see a few places selling? I'm also curious about the generator side scoop as I am running our generator pretty hard.
MrTube is offline   Reply With Quote
Old 12-16-2010, 09:32 AM   #9
steve s
steve s's Avatar
...--or why not a 4-blade steel like has been the mainstay for decades and decades? ...
Here's a reason to not use the repro 4-blade steel fans.
steve s is offline   Reply With Quote
Old 12-13-2010, 09:15 AM   #10
John LaVoy
John LaVoy's Avatar
Several years ago we did a comparison of fan performance and you get as much air flow with the original style two blade as with the others. This is in the Spring 2007 Model A Times. As far as the pump I have been running pumps from James Rupert 661-589-5795. He modifys original style pump housings.
John LaVoy is offline   Reply With Quote
Old 12-13-2010, 10:39 AM   #11
Jason in TX
Jason in TX's Avatar
Here is an extensive discussion on Leakless water pumps and the differences in them.
https://www.fordbarn.com/forum/showth...8945&showall=1
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 12-13-2010, 12:13 PM   #12
Tom Wesenberg
Tom Wesenberg's Avatar
As far as I'm concerned the best leakless pump was made by Henry Ford.
I rebuilt my original pump 10 years ago and it's identical to the original build, except I added the locking collar on the front of the shaft. This way one pump will be correct for any Model A, instead of relying on the head for the pump shaft spacing. I installed my pump 6 years ago and it hasn't leaked a drop yet. The secret is to use grease around the lead rings when you install them.
The only change I would make is: on all future rebuilds I'll use the rear brass bushing with the double lip seal. This will help to ensure that the grease won't get into the coolant. Also, I always use 50% antifreeze for freeze protection, water pump lubricant, and rust prevention.
Old 12-13-2010, 06:58 PM   #13
josh1331
thank you all for the feedback,i appreciate very much ,now i will try to figure out what is best for me.
merry christmas to all and a happy new year/josh
Old 12-16-2010, 04:13 AM   #14
sturgis 39
A good copper radiator is the trick to keeping a model "A" cool. I like the looks of the two blade fan. Pooch avatar is cool with the two blade fan. Somebody sells a serpentine belt system with a six bladed plastic fan. I probably will not buy one. I have some old Dodge power wagons. The fans on these trucks move a lot of air. You can not add fluids with the engine idling.
Last edited by sturgis 39; 12-16-2010 at 04:24 AM. Reason: added power wagon verbage
Old 12-16-2010, 09:38 AM   #15
steve s
steve s's Avatar
Originally Posted by sturgis 39 View Post
... Somebody sells a serpentine belt system with a six bladed plastic fan. I probably will not buy one. ....
Here's a picture of the serpentine system. It's sold by Dennis Cling in CA. The goofy looking uneven spacing of the blades is supposed to breakup harmonic vibrations. Strictly for guys who aren't concerned about judging points!
