Old 09-12-2017, 07:59 PM   #1
fred93
fred93's Avatar
Default 29 Tudor interior side panels question
Before I started restoring this 29 Tudor someone had already removed the interior, so I am not sure how things go back together. Is there anyplace that might have a video about interior install?
I have a question about the tabs on the rear seat bottom support frame--please see picture.
fred93 is offline   Reply With Quote
Old 09-13-2017, 05:49 AM   #2
aermotor
Default Re: 29 Tudor interior side panels question
The side panels are held in place there. FWIW, I made my none point car panels out of .025 6061-T6 aluminum from Aircraft Spruce.
John
aermotor is offline   Reply With Quote
Old 09-13-2017, 06:27 AM   #3
Tony Hillyard
Tony Hillyard's Avatar
Fred 93. This is the interior of my Canadian built 1928 Tudor. You can just see that the tags are used for the interior panel.
The last time I looked under the back seat the stuffing was not there. I must have had some visitors!!!
Tony Hillyard is offline   Reply With Quote
Old 09-13-2017, 07:23 AM   #4
2manycars
2manycars's Avatar
I installed 1/4 inch square hardware cloth to the back sides of the seat cushions to keep the mice out. I also put plugs in the two drain holes under the seat in the floor pan. I once saw a mouse scramble through that half in hole.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 09-13-2017, 08:55 AM   #5
Tony Hillyard
Thanks, I will try filling those holes up. The mice once demolished the interior of my 1925 Renault NN. I have tried everything to keep them out. The best things were French onions. But filling in the holes sounds the best bet.
Old 09-13-2017, 10:22 AM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
EVERYONE needs a Rat Terrier!
Bill Mousefree
"THE ASSISTANT GURU OF STUFF"
Old 09-13-2017, 11:58 AM   #7
fred93
fred93's Avatar
Thanks for the photo. And all the replies
