09-08-2017, 11:48 AM | #1 |
Is this speedometer cable routing correct?
Is this routing of the speedometer correct for a late model '31 CCPU or should it be through the ignition box?
Thanks Last edited by MickeyT; 09-08-2017 at 12:04 PM. |
09-08-2017, 12:16 PM | #2 |
Re: Is this speedometer cable routing correct?
Here is a photo of the correct routing. The cable should be painted black.
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
09-08-2017, 01:55 PM | #3 |
Don't forget the rubber grommet in the firewall hole.
09-08-2017, 03:28 PM | #4 |
Thanks Greg. I got it but has to be the wrong one. The I.D. is way too big.
09-08-2017, 05:14 PM | #5 |
the speedometer cable rubber grommets in the firewall do have to big of a I.D. why ford did that is another mystery
09-14-2017, 10:24 AM | #6 | |
TerryO |
09-14-2017, 03:12 PM | #7 |
Interestingly the RHD routing is different . The cable enters the car through an angled slot in the upper floor board . It does make a smoother run so I have done this route on my LHD cars .
John in weather was cancelled today Suffolk County England . |
