#1 |
This 31 model a was starting fine, has new battery. This morning wanted to move it and the starter 'clunked' and was locked up. I cannot get it to release.
Any ideas ? ? ? Thanks. [email protected] |
#2 |
Common problem with old cars. Put the car in high gear and rock it back and forth, you will hear a snap and be back in business. I had my John Deere do that today. Since it is a crawler, it would take several men to rock it, so I put it in neutral and used the hand crank. This isn't as good as rocking but it worked the second time I kicked the hand crank.
#3 |
Put it in 3rd and rock it backwards!!
Before Walmart you had to buy a ticket to the fair to see a bearded lady! |
#4 |
BAckwards only.
#5 |
You can unlock it by rocking in 3rd gear, however mine was beginning to do it a lot, needed a new starter drive spring and have since had no problems,!!
#6 |
If it does break free but you find it's happening more frequent, you may want to lubricate the bendix on the starter (not too much but just enough to allow free movement) |
#7 |
Mine used to do it a couple times a year, since I replaced the ring gear no more problems the last 25 years
The ring gear gets the teeth blunted and worn usually in 2 spots--- sometimes a little work with a dremel putting the tapers back and cleaning up burrs can get you by |
#8 |
And be sure the ignition key is OFF when you rock the car in gear! It's easy to forget to turn it off when the starter locks up and you raise the hood to diagnose the problem. Should you rock the car in gear with the key still on, there's a chance the engine will start and the car takes off. 'Hasn't happened to me, but I'm sure one of the millions and millions of Model A owner in the last 85 years had this happen!
Marshall |
#9 |
Had several Bendix springs break or shear bolt break, now only will use new style type.
