#1 |
I have a 31 model A with the rear hubs disassembled. I purchased new seals that go between the bearing and snap ring, but there is about another 1/4 " of space in the hub. What part am I missing? Is it the felt washer I've seen reference to? One print I've seen shows a felt on each side of the bearing but no seal. Again, the only parts I have to install in the hub are the bearing itself, the seal and the snap ring. Please help.
#2 |
Hi war2guy,
I'm at the same place with mine today so I looked at a couple of drawings, It shows nothing but the bearing but I'm new at "A's" so I could be wrong. Rear End https://www.brattons.com/assemblies/...-assembly.html Rear Brakes https://www.brattons.com/assemblies/...sembly-16.html Regards Bill |
#3 |
Tap the seal in just enough to install the snap ring. You don't want the bearing trapped by the seal.
#4 |
That's about right. There is more room than you would expect.
#5 |
I bought the seal installation tool from Brattons. It works great. REAR HUB SEAL DRIVER -
Use this tool to help you install the grease seal #1560 to the correct depth for the snap ring installation. Tool only no seal. 1560T 28-31 $19.95ea. Supergnat |
#6 |
Never thot about it but the idea to grind off the backwards bevil so snap ring pliers will work is a good one. thnks. ken |
#7 |
Wear eye protection when reinstalling that snap ring!
#8 |
Thanks very much for all of your help. I think I'm good to go!
#9 |
Hand pack the bearing with Mystik JT-6 High Temp Red grease, and you should be good to go for years. Don't use the grease zerk.
