Old 08-28-2017, 03:39 PM   #1
Minn-Tex Lee
Minn-Tex Lee's Avatar
Default How SWEET the sound
I just got my new manifold gasket and gland rings. The replace process went very well. No parts left over etc. I didn't know the torque value for the manifold nuts so I will go with 50# unless you folks know better. I took it around the block (4 miles) and she ran and sounded really nice. Thanks so much for all of your assistance on this problem.
Till next time.
Lee
Minn-Tex Lee is offline   Reply With Quote
Old 08-28-2017, 03:57 PM   #2
SeaSlugs
SeaSlugs's Avatar
Default Re: How SWEET the sound
i Thought 45# was good. check them after they cooled down just like head nuts.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 08-28-2017, 04:49 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Tex,
Don't post your TORQUE VALUE, guys will argue, even in 1 Lb increments--LOL
Bill Secretive
"THE ASSISTANT GURU OF STUFF"
Old 08-28-2017, 05:08 PM   #4
RawhideKid
Originally Posted by bill williamson View Post
tex,
don't post your torque value, guys will argue, even in 1 lb increments--lol
bill secretive
x10!!
Before Walmart you had to buy a ticket to the fair to see a bearded lady!
RawhideKid is offline   Reply With Quote
Old 08-28-2017, 05:09 PM   #5
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Did you use brass nuts?
Old 08-28-2017, 06:17 PM   #6
Hoogah
Hoogah's Avatar
. . . from the brass monkey?
Hoogah is offline   Reply With Quote
Old 08-28-2017, 09:52 PM   #7
1crosscut
1crosscut's Avatar
I don't use a torque wrench on manifold nuts. Matter of fact I just got done changing a blown gasket today for a club member.
I use a 1/2" drive socket wrench and tighten each one up a little at a time keeping the "torque" even across all four. I keep doing this until they snug up good and quit moving. If I put a little bit more grunt into it I could get them to move some more if I wanted.
Check em again after a hundred miles or so until they settle in.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 08-30-2017, 06:12 AM   #8
Wick
Wick's Avatar
Leave the torque wrench alone. Snug the nuts up,start motor...no leaks then drive till motor is hot.
Now go back and snug nuts some more before the motor cools. About 50 miles later check the nuts.
That's it,leave them alone. Also tap the Muffler clamp with a hammer a few times,this sets the clamp better. You will find the bolts very loose. Tighten, tap,tighten, tap. You will have a leak free exhaust for years.
Wick is offline   Reply With Quote
Old 08-30-2017, 06:29 AM   #9
Bob Bidonde
Bob Bidonde's Avatar
Those large thick washers should have a cup shape, and the concave side goes toward the manifold. These washers are actually springs that enable thermal expansion. Whatever you do, do not compress the cups flat. Follow Wick's instructions.
Bob Bidonde
Bob Bidonde is online now   Reply With Quote
