#1 |
I have one of the new 5.9 heads on my model A. What should my points setting be? What about a 5.5 police head on my other car.
#2 |
I tight 0.020.
#3 |
Stock points gap .018 to .022, you may want to play with spark plug gaps, I think I'm down to .032 or .030. 6.0 head, larger valve's, touring cam. Have fun playing around with different settings :-) I changed out 3x plugs to w18 plugs
#4 |
Point gap shouldn't change because of compression ratio. Spark plug gap may have to be reduced depending on coil being used.
#5 |
I am running a 5.5:1 head, a 12V Bosch hi-voltage coil, Motorcraft TT10 plugs with an 0.027" gap. I iterated the plug gap and spark advance adjustments, to find by the seat of my pants the best engine performance.
Bob Bidonde |
#6 |
Bill Practical
