Old 07-29-2017, 04:49 PM   #1
RalphM
RalphM's Avatar
Default Bad power valve?
So my car started running crappy last weekend and I just now started looking at it. I pulled the top off the carburetor today and it was completely bone dry. It had no acceleration would not pull up a hill. And a little backfiring.
The carb is a chandler groves 94, and i rebuilt it a couple years ago.
I suspect a leaking power valve, but some advice from the carb experts would be appreciated.
Thanks.
RalphM is offline   Reply With Quote
Old 07-29-2017, 05:03 PM   #2
flatheadmurre
flatheadmurre's Avatar
Default Re: Bad power valve?
If it drains the bowl...probably the powervalve.
Old 07-29-2017, 06:19 PM   #3
Ol' Ron
Ol' Ron's Avatar
Get a kit from Charley NY.
Old 07-29-2017, 08:59 PM   #4
RalphM
RalphM's Avatar
Thanks, I was pretty sure that's what it was. I will fill it here in the shop and leave it overnight to make sure.
Old 07-30-2017, 12:10 AM   #5
fortyonerag
fortyonerag's Avatar
I had a similar problem.
My new power valve leaks too!
How do I contact Charley?
fortyonerag is offline   Reply With Quote
Old 07-30-2017, 02:47 AM   #6
flatheadmurre
Probably not the new powervalve that leaks...but some sell the newer style that doesn´t seal as it should.
Old 07-30-2017, 08:57 AM   #7
fortyonerag
Same result tho'?
Old 07-30-2017, 09:11 AM   #8
Charlie ny
If interested my email is [email protected] I've dragged everyone thru this
but here goes one more time. I get my PV's from Daytona Parts, extremely reliable in
my opinion. I machine each PV to insure the gasket face is flat and square with
the 1/2-32 threads. The gaskets I supply are made by me using a medium hard grade
of nylon .501 id x .75 od x .040 thick . The purchased molded nylon gaskets, that
I've tried are too hard in my opinion. For sure none of this is rocket science but it
works for me. Prior to threading the PV in I like to use a carefully applied 'ring' of blue
locktite to the threads.
I'm asked frequently why all this fuss with PV's, here's why: vintage PV's were made in
a precise manner with no parting lines going across the gasket surface and they did
not have to stand up to corn gas......that's a biggy. At one point I was using a source
that seemed very durable, unfortunately after a month or so the diaphragms gave up.
Because I have great customers like Frank Miller and Dave Collete among many others
they stayed with me while I sorted things out.......that was a real rough spell.
Charlie ny
Charlie ny is offline   Reply With Quote
Old 07-30-2017, 12:13 PM   #9
RalphM
RalphM's Avatar
Sounds like you have taken a good product and made it better! Sent you an email Charlie.Do they use the leather accelerator pumps in their kits also?
Old 07-31-2017, 08:42 PM   #10
fortyonerag
Charlie,
I have emailed you also. Many thanks.
Old 08-01-2017, 06:38 AM   #11
Frank Miller
Frank Miller's Avatar
Thanks for the mention. Hope to see you in dearborn.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
