#1 |
Okay, I don't get it. What's missing? Is it a fuse? If so, what kind and amp?
#2 |
The wiring diagram shows three connections for the clock : light power tied to the dash dimmer swich, a ground, and a fused power line for the clock itself. Haven't seen a spec for the rating but as the line is connected to the lighting breakers, I would believe that we're looking at 2 amps or less.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
#3 |
There are just two wires to the clock. One for power and one for lighting.
All grounding is thru the body.
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 07-28-2017 at 07:28 AM. |
#4 |
#5 |
#6 | |
#7 |
Since my car is 12V, do I want to put the same kind of voltage reducer to the clock like I did with the gauges?
