Old 07-21-2017, 04:17 PM   #1
House of Fab
Default spring perch mounts for quick change banjo with torque tube or open drive
City: Ashland
State: VA
Price: 150.00
Here is a spring perch that will bolt/weld on your banjo quick change rear that rotates the banjo to the rear 5 degrees.
These brackets compensate for the rear axle assembly to rotate towards the rear, allowing the torque tube and driveshaft to align with the transmission, and can be used if your running an open drive shaft.
150.00 which includes shipping to the lower 48
Here is a link to the straight up spring perches for standard banjo rear
https://www.jalopyjournal.com/forum/...rsion.1067209/
Spring perches are available as 2" wide for Model T spring or 2 1/4" for Model A spring
The first pic shows the straight up version on the left and the 5 degree version on right.
House of Fab is offline   Reply With Quote
Old 11-23-2017, 08:12 AM   #2
House of Fab
Default Re: spring perch mounts for quick change banjo with torque tube or open drive
Bttt
Old 03-05-2018, 06:52 AM   #3
House of Fab
bttt
Old 06-04-2018, 06:38 AM   #4
House of Fab
bttt
Old 08-03-2018, 07:58 AM   #5
House of Fab
bttt
