Old 07-14-2017, 01:19 PM   #1
JOHN CT
JOHN CT's Avatar
Default Speedometer cable
The speedometer cable in my 31 is squeaking up by the speedometer. I'm going to remove it from the car, and I'm looking for your opinions. I would like to know what i need to do to pull the cable out of the housing? Am I able to remove the cable out of the housing easily just by pulling it out with a pair of pliers ? The speedometer works so the cable isn't frozen.
Do I need any special tools? The big question is will the cable go back in the housing without any problems??
Thanks
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 07-14-2017, 01:28 PM   #2
Spokes
Default Re: Speedometer cable
It's Been A while, As I Remember I Took The Cable Housing Off On Both Ends, Pulled The Cable Out With Pliers From The Speedo End. As Long As Your Cable Is In Good Shape It Probably Just Needs Some Lube. !!!
Spokes is offline   Reply With Quote
Old 07-14-2017, 03:26 PM   #3
SeaSlugs
SeaSlugs's Avatar
yup - cleaned and lubed... Throw an old sheet over the seats and wear old clothes and gloves - that graphite goop thats usually used on spedometer cables stains and whips around everywhere.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 07-14-2017, 06:42 PM   #4
old31
x2 as to what Seaslug said.
I have had very good luck with this product.
http://www.acehardware.com/product/i...ductId=3506024
