07-04-2017, 03:24 PM | #1 |
C4 transmission not shifting
Can an engine backfire blow out a modulator so the transmission doesn't shift properly on a '68 Ford C4 transmission?
07-04-2017, 07:03 PM | #2 |
Re: C4 transmission not shifting
Check your vacuum connections - the C4 will not shift without vacuum
I doubt that an engine backfire will knock out a modulator, but replace it if its got a lot of miles and years on it.
07-05-2017, 06:21 AM | #3 |
Easy way to tell if the modulator is blown, pull the vacuum hose off of it, if oil drips out its blown.
07-05-2017, 07:09 AM | #4 |
Thank You for your replies.
07-05-2017, 11:01 AM | #5 |
Could have blown the hose off =]
07-09-2017, 10:37 AM | #6 |
07-09-2017, 11:43 PM | #7 |
you might try adjusting the bands, it may help things a bit.
07-14-2017, 06:46 AM | #8 |
Thank You for your replies, I appreciate your help.
07-16-2017, 12:30 PM | #9 |
I was finally able to get under the car yesterday, I found the hose going to the modulator dry rotted and cracked. I replaced it and the transmission shifts well. Thanks to all who offered help.
07-16-2017, 02:37 PM | #10 |
If any of the rubber fuel lines are even close to the same age, replace them too.
