Old 06-28-2017, 03:23 PM   #1
Brianfrench65
Brianfrench65's Avatar
Default Idle speed
I've installed a Marvel Shaber carburetor. When I idle with the spark fully retarted, I get a real nice low idle. Maybe to slow??
I notice the ampmeter goes from a slight charge to a slight discharge.
I do have the generator lookalike alternator (Powermaster).
With the spark advanced 1/4 way down (for slow driving), the ampmeter stays just slightly above "0".
Should I adjust up the idle slightly, so I stay positive when idleing with the spark fully retarted?
Or am I good as is?
It does not stall out.
Thank You;
Brian French; 1930 Briggs Town Sedan
Brianfrench65 is offline   Reply With Quote
Old 06-28-2017, 03:51 PM   #2
wmws
Default Re: Idle speed
I would leave it alone. Your not idling that much that it would drain the battery.
wmws is offline   Reply With Quote
Old 06-28-2017, 03:58 PM   #3
Art Newland
Art Newland's Avatar
Once the alternator is turning really slowly, it will quit charging and needs to spin faster again to "self-excite" and start charging again. Mine does the same and isn't any problem.
Art Newland is offline   Reply With Quote
Old 06-28-2017, 04:01 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
I don't idle an engine more than necessary, and I always have my spark lever half way down at idle.
Idle speed should be about 475 RPM.
If you want to show how slow an engine can run, an old hit and miss is good for that.
Old 06-28-2017, 04:53 PM   #5
Kurt in NJ
Kurt in NJ's Avatar
I set my idle speed at parade walking speed, this way i don't need to ride the clutch
In the owners instruction book it says that there will be a discharge showing at idle and with the headlights on--- that it is normal
Old 06-28-2017, 05:52 PM   #6
Brianfrench65
Awesome; thank YOU ALL for your responses.
Thank You;
