#1 |
my coupe steering wheel rocks back and fourth. are the triple gear set worn out inside? maybe a bushing . can anyone help give me insight to what I should look for?
Mark Papa |
#2 |
Not understanding. If you mean all the time while moving, I'd say check each wheel ( 4 ) for out of true. If you mean at certain speeds, then it is possible it's a balance issue.
It is also possible that you need parts, or adjustments. Begin with the front spindle bearings. Then check tie rod end king pins etc. The triple gears may be worn, however if this occurs while moving I'd be suspicious of the frond end assembly. More description of the symptom would help in figuring this out. Good Luck
Enjoy yer day. Tom ![]() Hate can't fix what it started. |
#3 |
Two connections in action here.
First the domed nut on top holds the steering wheel spider fast to the steering gear pinion ( short shaft with gear on it). Loose nut may let the spider rock on the shaft if they are not a tight fit. Second the steering gear pinion continues on as a plain shaft beyond the gear. This fits into the steering gear post ( long shaft down to the bottom of the column). A loose fit between the 2 will let the steering wheel rick around. Hope this helps. |
#4 |
If what the others say is not helping, check the pins that hold the gears in place. You will have to take your steering wheel off as well as the gear housing cover though. You can also inspect the gears at the same time, I've found the pins wear out before those gears do.
#5 |
i have unscrewed the steering gear cover with the steering wheel on.
There might be a small pin or set screw in the top of the cover that prevents it unscrewing as the driver turns the wheel. Remove that first. Then if the gears seem loose on the pins you'll know what the problem is. Every worn gear i've seen seems to wear an egg shaped hole in the triple gear.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
#6 |
สล็อต ออนไลน์ ได้ เงิน จริง goldenslot |
