Old 06-24-2017, 05:18 AM   #1
Mercury 1953
Post Temperature sensor or
Hello
Has a problem with the temperature of a Ford flathead 1953. When the ignition is switched on, the temperature gauge is hot (it should be or?). When the engine is running then it falls to cold. Could it be the temperature sensor on the right half that does not work? Is it possible to measure it in any way?
Mercury 1953 is offline   Reply With Quote
