Old 06-16-2017, 02:33 PM   #1
nick c
Default 29 ccpu side window glass
I just received my glass kit after 5 wks. The side glass at the 2 top corners has a radius of 3/8", my door has a radius of 1 3/4". The supplier does not know much about it, so he gave me the number for Vintage glass but they are closed till Monday. I bought a channel kit and it has a piece of flat sheet metal that goes across the top that fits the radius of 1 3/4". Help what should I do?
thanks nick c
nick c is offline   Reply With Quote
Old 06-16-2017, 03:23 PM   #2
Gunmetal blue2
Gunmetal blue2's Avatar
Default Re: 29 ccpu side window glass
Did they give you the right piece for the back window, they my have gave you the wrong year or model. Please let me know because I also have a 29 AA. Sorry mine didn't have any windows in it when I got it. Nick were you from?
Gunmetal blue2 is offline   Reply With Quote
Old 06-16-2017, 03:23 PM   #3
rocket1
I went out to the garage to look at my 29ccpu door glass,the radius at the top corners is about 3/8,the trim on the inside around the window has right angle corners at the top.I had my glass cut using the old plate glass as a pattern,I have no idea what that flat piece of metal would be for.
rocket1 is offline   Reply With Quote
Old 06-16-2017, 03:34 PM   #4
1955cj5
1955cj5's Avatar
Is the 1 3/4" radius measured at the door frame as in the first picture?
The glass has a much smaller radius...maybe 3/8"...the glass slips up inside the door frame.....
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 06-16-2017, 04:33 PM   #5
Joe K
Joe K's Avatar
The pattern SHOULD be according to the Ford published glass chart.
Note that the glass for the 28-29 CC pickup is the upper LH corner. There is an error on the chart mislabeling the Tudor glass (which on the upper LH they mean the Model T Tudor) which might confuse.
Note also that a radius for the upper corners of this glass is not specified except "round & polish." Other later glasses have "break corners" or specific radii. I think a radius here is not critical providing the corner isn't so sharp it "hangs up" on the hairs of the channel.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 06-16-2017, 06:25 PM   #6
nick c
Thanks to all for the help.
Gunmetal front and back glass fit good, Miami and Ocala fl.
Cj5 first pic, yes.
My window channel kit came from mikes,A45983pu $60.00. as you can see from the pic, the sheet metal strip is 3/4" x 27 3/4" long with 3 holes for machine screws 8x 32. it fits the inside radius of door and ends up perfect on top of channel, then glue on molded rubber. Now I will have to bend the metal strip out straight and raise the felt channel 1" to meet the foam rubber.
thanks again, nick c
Old 06-16-2017, 08:00 PM   #7
Gunmetal blue2
Thank you all it will help me when I get that far.
Old 06-16-2017, 08:05 PM   #8
Keith True
Keith True's Avatar
The glass guy I use asks people what they want for a radius.His measurements are,pencil eraser,dime,nickel,quarter,or a half dollar.Most can't seem to understand what the radius will look like if given in numbers,but everybody can picture the curves of a coin.
Keith True is offline   Reply With Quote
