#1 |
Has the 2-piece neoprene/cork rear main seal improved in quality and long-term effectiveness in the last couple years?
#2 |
The Dog "sed" he hasn't heard any news about it!
Bill Dogman
#3 |
I prefer the Burtz, used as a 1-piece.
#4 |
The two-piece cork/neoprene rear seal is fairly rigid and functions as a "pinch seal" much like the front seal albeit with a much greater oil flow. This requires just the right amount of pressure over the entire circumference and this can be a challenge given the possible variations in fitment within the upper and lower caps with respect to the centerline of the shaft. Too much pressure and wears fast and leaks and too little pressure at any given point and it will leak there. I have been told that the old design can be effective but only if one take extra time and effort to achieve a good fit. I don't know if there have been any improvements in design over the last couple years.
#5 | |
![]() Quote:
The same words can be used to describe the proper installation of any rear main seal in an A/B engine, i.e.- install by one who knows how to achieve a GOOD fit ! I do not know of any recent improvement in the two piece cork/neoprene rear seal. However, I second Jim B use (Terry Burtz) of the one piece real seal...properly fit. I have two such installs running in B engines at this time, with neither leaking at all. |
#6 |
#7 | |
![]() Quote:
Google search turned up no info. Wondering about source/maker name ? |
#8 |
Sorry, I didn't have the correct name. Google "clipper split seals" and you will find they are made by Johns Manville, Parker Hannefin, et al. They appear to be placed around the shaft and secured at the split by means of a "hook-and-eye" closure. Looks interesting.
#9 | |
![]() Quote:
![]() I'm now wondering if that type seal is what is used in some new vehicle engines ? |
