Old 06-08-2017, 07:52 AM   #1
hotrodcbx
Default Source for Potvin 3/8?
Who sells Potvin super 3/8 cams and good quality adj. lifters????
hotrodcbx is offline   Reply With Quote
Old 06-08-2017, 07:58 AM   #2
JSeery
JSeery's Avatar
Default Re: Source for Potvin 3/8?
You can still get Johnson lifter direct from the supplier, they are the solid type.
Part number B 2032 / 125+0455
NOPI Div of Topline
http://hylift-johnson.com/wp-content...talog_2014.pdf
Old 06-08-2017, 08:22 AM   #3
Bored&Stroked
Bored&Stroked's Avatar
Send a message to the member named 'Pete' -- he has been grinding flathead cams longer than I've been alive (and I'm 58). He can regrind a stock cam core to the Potvin 3/8 grind - I've had a lot of flathead friends get cams from him . . . you'll be pleased with the quality of his work.
Ping me if you need help.
B&S
Old 06-08-2017, 09:36 AM   #4
GOSFAST
GOSFAST's Avatar
If you need the original Johnson's just contact me either with an e-mail: [email protected], or a P.M. here.
Occasionally we find the lifters are on back-order, it's rare but it has happened. With this in mind we try to keep a fairly large supply here at all times, so far, so good.
Thanks, Gary in N.Y.
P.S. Just arrived this week, couple hundred lifters and valve springs strictly for the Flatheads. Shots here show the "Topline" lifters brand and "Associated" valve springs!
File Type: jpg Flathead Johnson Lifters-Valve Springs.JPG (70.5 KB, 72 views)
GOSFAST is offline   Reply With Quote
Old 06-08-2017, 06:39 PM   #5
russcc
Are the Topline lifter made in China ?
russcc is offline   Reply With Quote
Old 06-08-2017, 08:07 PM   #6
JSeery
JSeery's Avatar
Did you look at the link (#2)? Believe that is covered with photos and all.
