05-29-2017, 03:04 PM | #1 |
Can I use a horn relay for fog lights?
On my stock 6 volt system can I use a horn relay to run my fog lights?. Is there really a differance between light and horn relays. I have an extra horn relay laying around.
05-29-2017, 03:07 PM | #2 |
Re: Can I use a horn relay for fog lights?
No problem I can see.
Alan |
05-29-2017, 03:28 PM | #3 |
Yes. My '41 had a horn relay for fog lights. I removed the lights for better looks.
05-29-2017, 04:25 PM | #4 |
Horn relays are designed for short period of time usage as are starter relays (which are also sometimes used). I use a relay that looks like an original starter relay but designed for prolonged usage. Using the short term relays for a long term application seems like a miss usage (from a design prospective) to me, BUT many have done it and it seems to work!
05-29-2017, 06:14 PM | #5 | |
Bruce
Works good Lasts long time |
05-29-2017, 07:10 PM | #6 |
05-29-2017, 08:19 PM | #7 |
Use a constant duty solnoid, it will look like the starter one but it is built for constant duty, NAPA has them
05-29-2017, 08:29 PM | #8 |
05-30-2017, 10:01 AM | #9 |
Thanks I'll check with my local NAPA, even if they don't have it they are pretty good at ordering stuff.
05-30-2017, 12:36 PM | #10 |
Those constant duty solenoids are relatively expensive. What do they do for a lighting circuit that a $4 relay won't do?
05-30-2017, 01:46 PM | #11 |
Not sure why a relay is needed for fog lights, which do not draw that much current. The headlights draw more and they do not use a relay; - just a switch on the dash. Why not just power the fog lights through the fog switch on the dash. Need a wire from the headlight terminal of the circuit breaker unit to the switch, and a wire from that switch to the fog lights. Use a wire the same diameter as headlight wire. Be sure both fog lights have a good ground. You avoid the current drain of the constant-use relay, and have one less component to go bad.
05-30-2017, 01:55 PM | #12 | |
Just checked, Ford didn't start using a horn relay until 38 according to the wiring diagrams. Last edited by JSeery; 05-30-2017 at 02:03 PM. |
05-31-2017, 06:40 AM | #13 |
A relay is where a smaller switch turns on a bigger switch. I do not see why a horn relay would not work as long as it is rated for the current of the lights. Horn relays I believe were used to eliminate voltage drop through a marginal horn switch. I know ModelA owners use them to get full voltage to the motor. Momentary relays are usually ones like starter solenoids, which is a relay but has to overcome spring pressure to engage. The OD solenoid does not engage a switch but utilizes a pull in and a holding coil which requires less current.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
