Old 05-25-2017, 02:48 PM   #1
denniskliesen
denniskliesen's Avatar
Default Searching for body codes
After reading another thread regarding early to mid 28 Tudors, I didn't want to hijack that thread so I decided to start one here. I was having a tough time locating my body plant code from instructions members provided here. Apparently most body codes were on the front body crossmember, but my crossmember was flat and clean with no numbers. I decided to expand my search in areas close to the crossmember without removing the floorboards. Sure enough there it is, on the side rail. Only thing I was stumped over was no letters, only numbers. So I did a search here on body codes and ended up going to MARC to the site Ford assembly plants and body codes written by Dave Sturges. From this information only Denver stamped the side rail to my understanding. So I am assuming my Tudor built in 1929 that has a tank date 1-21-29 and body code 3061 2 29 was built in Denver in Feb 1929. quoted from MARC "It only takes a few minutes to locate the body assembly plant number, if there is one to be found. Just lift the front floor mat or carpet and look on the top of the front body cross member in front of the seat riser or support or on either side rail. The only assembly plants known to stamp assembly plant number on the side rail is Denver."Can anybody tell me what those first 4 numbers stand for?
denniskliesen is offline   Reply With Quote
Old 05-25-2017, 03:42 PM   #2
jdupay
jdupay's Avatar
Default Re: Searching for body codes
Assuming it was the same system as every other plant, the number is the number of the body built at that plant. So that was the 3061st Tudor built in that plant
Joe
Minneapolis, MN
1929 Std Coupe
jdupay is offline   Reply With Quote
Old 05-25-2017, 03:43 PM   #3
jdupay
jdupay's Avatar
After I posted that I got to wondering if they carried over from year to year or within a year. Seems unlikely they cranked out over 3000 Tudor bodies in two months in Denver. Hmmmm. May need to do some more digging. Now I am curious
Joe
Minneapolis, MN
1929 Std Coupe
Old 05-25-2017, 03:52 PM   #4
jdupay
jdupay's Avatar
So Steve Plucker's PDF has a lot of good information and also has contact information for Dave Sturges who probably has the most information.
http://www.plucks329s.org/pdf/studie...ND%20CODES.pdf
Joe
Minneapolis, MN
1929 Std Coupe
Old 05-25-2017, 05:56 PM   #5
HoarseWhisperer
HoarseWhisperer's Avatar
4 digit body number on 1931 Canadian Roadster. No preceding letter.
I know a lot of things; I just can't remember them all.
1928 CCPU 82-A
1931 Roadster 40-B Dlx (Canadian)
HoarseWhisperer is offline   Reply With Quote
Old 05-25-2017, 10:44 PM   #6
Steve Plucker
LA did it also.
LA 9574 9-29 Standard Coupe
Old 05-26-2017, 10:01 AM   #7
denniskliesen
Steve, I haven't been able to find the letters in front of the first 4 numbers. So my Tudor could have been built in Los Angeles or Denver? Do you have a picture of the body number you mentioned? I'd like to compare the shape and size of the numbers.
Old 05-26-2017, 10:13 AM   #8
Dick Steinkamp
Dick Steinkamp's Avatar
Originally Posted by Steve Plucker View Post
LA did it also.
Did what?
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 05-26-2017, 07:32 PM   #9
Steve Plucker
Originally Posted by Dick Steinkamp View Post
Did what?
Assembly plant codes similar to Dennis's above.
Old 05-26-2017, 07:36 PM   #10
Steve Plucker
Dennis,
Go to post #4 and go to the website mentioned.
Pluck
Old 05-26-2017, 07:38 PM   #11
denniskliesen
LA did it also.
Do you have a picture of that?
Old 05-26-2017, 07:39 PM   #12
Steve Plucker
No but go to post #4 and go to thaT SITE.
Pluck
