Old 05-24-2017, 06:43 PM   #1
1928closed
Default 1928 gas cap
I have a 1928 closed cab pick up. Everything I read tells me I should have a threaded gas cap but I have a gas cap that has tabs and it seals on a quarter-turn. All the catalogs show the 28 29 gas cap is threaded and the 30 31 with tabs. Is it possible to have a tabbed 28 gas tank? Thanks
1928closed is offline   Reply With Quote
Old 05-24-2017, 07:15 PM   #2
wrndln
Default Re: 1928 gas cap
The 28/29 CCPU style cab went to July 1930. 1930 gas tanks had the quarter turn gas caps. I could be wrong, but I suspect someone installed an early 1930 gas tank on your pickup.
Rusty Nelson
Old 05-24-2017, 07:22 PM   #3
Bob C
Does it have a 7 tooth or 2 tooth steering gear with 30-31 type steering wheel.
Bob
Old 05-24-2017, 07:22 PM   #4
Mike Peters
Mike Peters's Avatar
Rusty, you just beat me to it. JS says the quarter turn cap was introduced in April, 1930 and continued through June, 1930.
Mike Peters is offline   Reply With Quote
Old 05-24-2017, 09:57 PM   #5
1928closed
Well I think I have a 1928, How can I tell the difference between a 7 tooth and a two tooth the steering column is out but not disassembled? I do not believe the gas tank has been changed as I am the one who removed it and it seems like it was the original install, paint matched and original welting was in place. I do have 29 headlights though. What are some other ways I can tell a 28 from a 29? As you can tell I'm new to all of this, any help is greatly appreciated. Where is the engine s/n stamped on the frame? I assume that will help.
Old 05-24-2017, 10:14 PM   #6
1955cj5
1955cj5's Avatar
The s/n was normally stamped on the top of the frame, just about 6" behind the left front body mount bolt hole..
Here is another thread that may help. Picture #2 in the first post is where it should be...
https://www.fordbarn.com/forum/showthread.php?t=221192
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is online now   Reply With Quote
Old 05-24-2017, 10:14 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
The 7 tooth steering has a one piece welded box and column, while the later 2 tooth steering has a clamp to hold the column to the main steering box.
Old 05-24-2017, 10:19 PM   #8
1955cj5
1955cj5's Avatar
There are pictures here
http://www.snydersantiqueauto.com/2-tooth-steering-box
http://www.snydersantiqueauto.com/7-tooth-steering-box
Old 05-24-2017, 10:19 PM   #9
Bob C
Check this picture for frame number location.
Bob
Old 05-24-2017, 10:25 PM   #10
SteveB31
SteveB31's Avatar
AA trucks used the tall cab like yours until mid 1930. The fuel tanks in the early 1930 AA trucks were the same shape as all 1928-1929 pickups, cars etc- only they had the non threaded 1/4 turn 1930 style cap.
SteveB31 is offline   Reply With Quote
Old 05-24-2017, 10:26 PM   #11
1955cj5
1955cj5's Avatar
When you find it enter it here...for the manufacture date of the engine.
http://www.modelahouse.com/cgi-bin/enumbers/numdate
Old 05-25-2017, 05:50 AM   #12
1928closed
Looks like I have a two tooth box which points to a 29 instead of a 28, right. Looking for engine number today. Thanks to all.
Old 05-25-2017, 07:05 AM   #13
Gunmetal blue2
Gunmetal blue2's Avatar
My 8-30-29 has the screw on gas cap.
Gunmetal blue2 is offline   Reply With Quote
Old 05-25-2017, 08:07 AM   #14
1955cj5
1955cj5's Avatar
You can also look at the firewall side of the gas tank, above the steering column..there might be a date stamped there..sometimes stamped upside down..
Similar to this
Old 05-25-2017, 09:39 AM   #15
Mike Peters
X2 Have you considered that the entire cab on your truck may be a transplant? Later cab on earlier chassis?
Old 05-25-2017, 11:04 AM   #16
JDupuis
JDupuis's Avatar
1928closed, welcome to the Barn. Where do you live? As you have have been informed; it is possible to have a 28/29 styled truck with the 30/31 1/4 turn gas cap. There are more out there then you realize. My Father-in-law has a AA with the later gas cap as well. Again welcome to the Barn, and post often. Jeff
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
Old 05-25-2017, 04:45 PM   #17
d.
easy enough...the 2 tooth is a 2 piece column, the 7 tooth is 1 piece column.
Add your location to your reply info. it can help in finding a local guy to help you.
d. is offline   Reply With Quote
Old 05-25-2017, 10:28 PM   #18
1928closed
Thanks, great information. Lafayette La
Old 05-26-2017, 04:33 AM   #19
1928closed
What does it mean when the serial number pad on the engine is blank?
Old 05-26-2017, 04:38 AM   #20
Tom Wesenberg
B blocks weren't stamped there.
Has the number been ground off?
Original number pads are raw cast iron, so they have the same rough surface as the rest of the block.
