05-22-2017, 07:17 PM | #1 |
Fuel pressure regulator
I just installed the E8902 electric fuel pump when my 51 sits for a week or
more its hard starting . I have two 94 on a offy intake I installed a toggle switch .will I need a regulator ? also I have a new double action fuel pump Thank you for any help in this . still 6 Volt |
05-22-2017, 07:37 PM | #2 |
Re: Fuel pressure regulator
Have almost same exact same hardware on my 39. No regulator (only difference I removed mech pump) and no problem. After week, turn car on, one pump to floor and car starts right up.
Thanks Andy 1952 F1 |
05-22-2017, 08:06 PM | #3 |
That is only a 4 psi pump. You really don't need a regulator if you are just priming the carb. On my Hobby Shop member cars I use a momentary switch so they will not leave it on. Run it for 15 to 30 seconds and you will be good to go.
05-23-2017, 06:08 PM | #4 |
I use a Holly reg with a sight gauge and keep the PSI around 2#. It works perfect.
05-23-2017, 06:11 PM | #5 |
My set up is like mike 42
05-23-2017, 08:30 PM | #6 |
05-24-2017, 08:35 AM | #7 |
I have the Airtex E8902 pumps installed on my '32 & '50 without the fuel regulator. Works fine. I use primarily for priming. I also recommend the "momentary" toggle switch, however; when driving in city traffic...you may need to keep your finger on the toggle switch to engage the fuel pump for longer periods (vapor lock). I removed the momentary toggle switch from my '50 in favor of a "momentary-off-on" toggle switch. Works great when you are experiencing vapor lock situations. I can't drive through Atlanta, GA without vapor locking it seems. Good luck, Pat
05-24-2017, 09:45 PM | #8 |
For many years I've had an Airtex pump and don't use a pressure regulator. It puts out 3 psi when measured at the outlet of the mechanical pump (engine not running). I use it to prime the carb at start-up.
My mechanical pump also puts out 3 psi. I understand 3 psi is at the upper recommended limits for a stock one-carb 59AB. Last edited by Drbrown; 05-24-2017 at 11:33 PM. |
