#1 |
This 2-bolt has a cast iron housing and is different where it connects to the cam shaft. What specific model/year did this fit?
Thanks! |
#2 |
I have one just like that , and it came off an Army Surplus engine.
#3 |
Do you mean Ford V8?
#4 |
Looks like 46-48 v8
#5 |
#6 |
#7 | |
![]() Quote:
The reason it appears "different" is the breaker plate is not installed in to the body properly.
#8 |
Actually i have a couple customers that prefer the cast iron unit. Looks pretty good , blasted and painted black.
The only difference with yours, is it isnt together other wise they are the same as the aluminum crab from 42-48. |
#9 |
The Canadians used iron distributors, and they spread all over the world via WWII in which Canada was a MAJOR source of Ford rolling stock. I have heard of the '42 USA connection but have never seen any evidence...if we made iron ones in '42 we also made regular die cast ones.
It should also be noted that Ford USA and Canada supply lines were intertwined during the war. Closely examine the pics in the Ford USA '37-48 rebuild book...the pictured engine would seem to be a wartime Canadian engine or perhaps a US engine fed through Canadian production...it is a '42-45 war engine with full flow oil hookup! |
#10 |
The G model 6-cylinder also used a similar distributor but it only had one set of points and the cam was for 6-cylinder. They may have been available in either metal too. War time material shortages may have had an effect on this.
#11 |
The '41 6 cylinder was the first "crab" to see production, same case as '42-8 V8 with the above noted 6 cylinder innards. Like the V8 it had two different cap arrangements over the years.
