#1 |
I would like to wire up a second horn in my 34, an Ahooga, using a Start button as a switch; (horn button ,) and a fuse inline with the horn , can someone tell me how to do this, or draw a circuit diagram, thanks in advance ..
#2 |
You need a relay to carry the current. A little more information is needed, do you want it to look somewhat original or could you care less?
#3 |
I'd have to agree that a relay would work best, but certainly many a Model A's horns work fine without a relay. Model A's horn has power to it all the time, the horn button provides the ground. Is your car 12 volts or 6? Positive or negative ground?
#4 |
This would be for a horn that required power to operate. If it requires a ground to activate, I would use a normal horn relay.
#5 |
