Old 05-09-2017, 09:13 PM   #1
ford35lh
Default Door locked - no key
I bought another 35' truck and while cleaning it out I caught the
door handle and locked it. But, it won't unlock. The glass is broke
and missing and I have prodded and poked everything with no
luck unlocking it.
I can see well down into the door.
Can someone tell me where the "U" spot (unlock) is ????
ford35lh is offline   Reply With Quote
Old 05-09-2017, 11:37 PM   #2
deuce lover
deuce lover's Avatar
Default Re: Door locked - no key
When you caught it ,it pulled up.Push the handle down
deuce lover is offline   Reply With Quote
Old 05-10-2017, 01:18 AM   #3
Talkwrench
Talkwrench's Avatar
When you push the handle forward it slides a bar in the internal mechanism its right behind the outer door handle, perhaps something has fallen in the mechanism and jammed this up . The plate that holds all this together broke on mine and I had to disassemble and weld it up again with great care.. Wasn't easy as I have central locking attached to it and had to be " just so' so the motor could work the lock.
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
