Old 05-08-2017, 06:51 PM   #1
Ian in Mississauga
Default KR Wilson hub puller
I have the loan of a KR Wilson ABV-156 rear hub puller. One of my hubs has a groove and one has a ring. WIll this puller work on both?
TIA Ian
Ian in Mississauga is offline   Reply With Quote
Old 05-08-2017, 07:22 PM   #2
wrndln
Default Re: KR Wilson hub puller
I don't know about the tool you have, but most old hub pullers worked on one type hub OR the other, but not both. I believe the hub with the protruding ring was used in 1928 and early 29 only. The later hubs had a groove on the hub.
Rusty Nelson
Old 05-08-2017, 07:37 PM   #3
Joe K
Joe K's Avatar
Its bound to fit at least one. Literature on the reproduction tool (discontinued from most suppliers now) indicates that it is to be used on the "groove" version only.
So do the one, try for a grab on the other and if it won't go to AutoZone and "borrow" a hub puller.
I have the "bearing splitter" which CAN be used for this sort of work. And can be used on either version. These also available for borrow at AutoZone.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 05-08-2017, 08:23 PM   #4
larrys40
Ian
The protruding ring was 28 and if that's the case it will not work.
There's a flip top clam shell type that I ligt from industro of the era.
U don't like the ones that go on the studs as they can distort the hub and drum although you might not have any alternative .
The suppliers also sell a 28 cast puller which should work as well
Ill try and post some photos later
Larry
larrys40 is offline   Reply With Quote
Old 05-09-2017, 08:29 AM   #5
JohnLaVoy
JohnLaVoy's Avatar
KR wilson made one for the groove which I have for the early car but it wont' work on the ring style.
JohnLaVoy is offline   Reply With Quote
Old 05-09-2017, 08:43 AM   #6
larrys40
John
I have that one as well but it bolts to the studs just the same which isn't preferable.
It's nos and has never been used and I don't necessarily plan to either .
Larry
Old 05-09-2017, 08:50 AM   #7
Ian in Mississauga
Thanks all, not what I wanted to hear but I will go to my local auto parts store and borrow the right tool. By the way, I know that there are different front hubs and the earlier one is more failure prone than the other (not counting the AR). Are the rear hubs equally safe?
Old 05-09-2017, 01:18 PM   #8
Chris Haynes
Chris Haynes's Avatar
Bratton's sell both types of pullers cheap.
https://www.brattons.com/catalogsear.../?q=hub+puller
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 10-03-2018, 08:24 PM   #9
Steve in Denver
Steve in Denver's Avatar
Anyone have an extra box for the KR Wilson ABV-156 rear hub puller? Or can send me a few photos, I can probably make one if I know what the insides look like.
File Type: jpg KR Wilson Hub Puller and Box ABV-156.jpg (47.7 KB, 67 views)
Steve in Denver is offline   Reply With Quote
