Old 04-29-2017, 04:14 AM   #1
DennisR
DennisR's Avatar
Default Door Seals
I have just bought some door seals. The upper inside ones go under the garnish, the slots don`t quite match up with the screws so a bit of filing will be required there, no problem. The bottom ones I can`t make up my mind which way they are supposed to go, I understand that they are sandwiched between the door and panel, I`ve looked back thru the posts and found one that shows them fitted but a comment was made about the correctness.
Also I would have liked to had a seal on the outside of the door to stop water running down the inside between the glass and the door but can`t find any, were they not available ?
Love a Lot, Trust a Few
Always Paddle Your Own Canoe
DennisR is offline   Reply With Quote
Old 04-29-2017, 07:11 AM   #2
Steve Plucker
Default Re: Door Seals
Look at the Service Bulletins...There is reference to the seals for the bottom of the door in there...not sure which page.
Pluck
Old 04-29-2017, 10:20 AM   #3
duke36
Some models had upper seals with a lip as part of the glass setting material. Some vendors sell those. They only work with the glass in the closed position. The lower door rubber seal mates against the body sill and is held in by the clips and screws at panel corners on some models. The vendors sell those also and they come with elongated holes for adjustment. It's a good idea to paint the lower inside of the door where the drain holes are, including the cowl and rear quarter sedan windows, etc.
duke36 is offline   Reply With Quote
Old 04-29-2017, 11:28 AM   #4
DennisR
DennisR's Avatar
Pluck
Did have a look thru mine but didn`t see anything, I`ll take a closer look......
Old 04-29-2017, 11:33 AM   #5
DennisR
DennisR's Avatar
Thanks, not too bothered about the top ones, if I do find them they can go on the `to do` later list.............
Old 04-29-2017, 07:24 PM   #6
duke36
Many years ago on a prior- owned tudor sedan, I glued dense rubber weather stripping to the bottom window channels so when the window is rolled up it pressed under the outer window sill skin.
