Old 04-28-2017, 03:13 PM   #1
Roadster Rich
Roadster Rich's Avatar
Default Engine Painting
Head is off, valve cover off and I am repainting both and then will try to paint the rest of the engine in place. I have a few dumb questions that some of you could help me with.
Do the machined flats for the head bolts and spark plugs on the head get painted? I can see that it looks like my Roadster that was painted back in the 60's might not have had them painted and it appears to have rusted around all those areas.
Is the intake manifold engine green or black?
Is the water pump green or black. Here again the Roadster is green but the water pump I am rebuilding is black???
Do you paint your exhaust manifold or leave it unpainted? I have bought new matching exhaust and intake manifolds and the intake is painted black from the dealer.
Thanks
Rich
Roadster Rich is offline   Reply With Quote
Old 04-28-2017, 03:26 PM   #2
Dick Carne
Dick Carne's Avatar
Default Re: Engine Painting
Hi Rich -
All castings would generally be painted engine green (engine, head, water pump, and intake manifold; stamped pieces, etc. would be black (e.g. starter, generator, oil pan). The two exceptions that come to mind would be the distributor casting (black) and the carburetor (also black). I would recommend at a minimum spraying the exhaust manifold with some sort of dark gray or black heat resistant paint, although you may also wish to consider having the manifold coated. Terry Mobley over in Jonesboro at Performance Coatings is an old car guy, and has heat resistant finishes available for manifolds as well as powder coating for wheels and other parts. Many of us on the south side of town have been pleased with his product. Good luck with your project.
Dick
Dick Carne is offline   Reply With Quote
Old 04-28-2017, 04:52 PM   #3
Gunmetal blue2
Gunmetal blue2's Avatar
I you have a cast iron sediment bulb that gets painted blk. most of the time.
Gunmetal blue2 is offline   Reply With Quote
Old 04-28-2017, 04:58 PM   #4
SeaSlugs
SeaSlugs's Avatar
in addition to whats been said the generator and pulley were black , starter black, flywheel housing and trans engine green and also the crankshaft pulley was engine green.
oil vent tube/fill was black, dipstick black, all the bolts for timing cover and water inlet were raven finish
uhh oil pan was green as well
oil return tube was black
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 04-28-2017, 08:12 PM   #5
vern hodgson
On the same subject, I have an engine block dated 1929 painted grey, does that have any significance??
vern hodgson is offline   Reply With Quote
Old 04-28-2017, 08:36 PM   #6
MikeK
MikeK's Avatar
That only means someone has been at it since it left the showroom. Most engines have been reworked, and in the 40's, 50's, 60's rebuilders used any color they wanted. Today most of us just want to make things as they were originally. That is, some shade of "Ford Green" which was a mix of leftovers and varied one batch to another. For the original look, all green parts should be the same shade close to what is now accepted as 'Ford engine green".
MikeK is offline   Reply With Quote
Old 04-28-2017, 08:47 PM   #7
vern hodgson
Thanx, was afraid it was from a combine or something.
Old 04-28-2017, 11:06 PM   #8
Larry Jenkins
I think oil pans were gloss black. Snyders carries a very authentic looking Ford Engine Green paint is spray cans.
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 04-28-2017, 11:09 PM   #9
SeaSlugs
SeaSlugs's Avatar
wait you might be right on the oil pan... And yes I luke Snyders green engine paint.
Old 04-28-2017, 11:42 PM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
The steel seamed tube for the generator wire (used in 28 and 29) is also gloss black.
Old 04-29-2017, 12:14 AM   #11
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
What is stamped as a serial number?
Old 04-29-2017, 12:18 AM   #12
Mike V. Florida
"The engine was assembled after the individual parts
were painted and therefore all gaskets were unfinished."
Page 1-18 of the Revised 2016 restoration guidelines has a chart of engine compartment finishes.
Old 04-29-2017, 12:54 AM   #13
denniskliesen
denniskliesen's Avatar
Yes Snyder's and Bratton's paint looks good to me, and when I got paint the last time I ordered from both. Same brand, same can, same color.
denniskliesen is offline   Reply With Quote
Old 04-29-2017, 07:31 AM   #14
Roadster Rich
Thanks to all for the help. I will paint the top of all the flat bosses on the head. And I will try some of the high temp black for the exhaust manifold. The engine was blue on this town sedan from some time back when, and I don't like it.
I did buy a can of Ford Engine Green a while back and it is a very dark almost black green. Much different than what my Roadster engine looks like when we rebuilt it back in Paige Model A days. One of the guys in the club here said it is the color that was painted in Canada and not the US???
Right now I am mixing the 2 parts John Deere green with 1 part black and it is almost exactly what my Roadster color is.
Off to work now.
Old 04-29-2017, 09:33 AM   #15
Tom Wesenberg
I had the same problem with a spray can of Ford engine green, that looked more black than green. I wonder if a bad batch went through a few years ago?
The last two cans I picked up at Little Dearborn look good, and I think they came from Snyder's.
Old 04-29-2017, 12:50 PM   #16
Chris Haynes
Chris Haynes's Avatar
Your engine long block was painted after it was assembled. Not while it was still in pieces. So the machined faces relieved paint after the nuts and bolts were installed.
All cast iron parts are green while all sheet metal parts are black.
Simple enough that even I figured it out.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 04-29-2017, 12:52 PM   #17
Chris Haynes
If it was an engine made for use in anything other than a car it would be a Diamond Block.
1921 Runabout
1930 Tudor
Early 1930 AA
