Old 04-15-2017, 02:29 PM   #1
bluzrocker
bluzrocker's Avatar
Default part came out of the rear of the motor
Can any one Idendify this part...
https://www.fordbarn.com/forum/attac...1&d=1492284459
bluzrocker is offline   Reply With Quote
Old 04-15-2017, 02:36 PM   #2
Dick Steinkamp
Dick Steinkamp's Avatar
Default Re: part came out of the rear of the motor
The part on the left is a quarter.
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 04-15-2017, 02:46 PM   #3
bluzrocker
bluzrocker's Avatar
you are a gem for that tid bit
Old 04-15-2017, 02:47 PM   #4
Art Newland
Art Newland's Avatar
Nyuk Nyuk Nyuk
The other looks like a hose washer.
Art Newland is offline   Reply With Quote
Old 04-15-2017, 03:18 PM   #5
lindy williams
It looks like an old after market attempt at a rear main seal. I had an engine with one in it. It didn't work.
lindy williams is offline   Reply With Quote
Old 04-15-2017, 03:24 PM   #6
bluzrocker
bluzrocker's Avatar
so how did you fix it?
will the motor have to be torn down to put in another?...and what type are guys using now and where to get one pls....do have a oil leak and been leaking....motor is new maybe 1000 or less miles since total rebuild
Old 04-15-2017, 03:55 PM   #7
1955cj5
1955cj5's Avatar
To me it looks too small to be a rear main seal...
It has letters on it...can you read them?
Sometimes they leak simply because the crankcase is over-filled with oil...
5 quarts in a completely new and clean engine
About 4 quarts for an oil change as about a quart is held in the dip tray and won't drain...
How much does it leak?
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 04-15-2017, 03:59 PM   #8
George Miller
George Miller's Avatar
Originally Posted by bluzrocker View Post
Looks like one of those most of the time leaking rear seal.
George Miller is offline   Reply With Quote
Old 04-15-2017, 04:01 PM   #9
Bob C
When you say it came from the rear of the engine was it in the oil pan
or do you mean the bell housing area?
Bob
Old 04-15-2017, 04:05 PM   #10
bluzrocker
bluzrocker's Avatar
H 25 only on one side
Old 04-15-2017, 04:08 PM   #11
bluzrocker
bluzrocker's Avatar
it was in the OIL CATCH BASIN small pan that fit under the bell housing to keep oil off the floor....so it was pushed out of the block I assume
Old 04-15-2017, 04:12 PM   #12
1crosscut
1crosscut's Avatar
Have you contacted the person that rebuilt it? Shouldn't be leaking with only 1000 miles on it.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 04-15-2017, 04:15 PM   #13
bluzrocker
bluzrocker's Avatar
yes we tried to ..but not in same location where the work was done...so no help from builder
Old 04-15-2017, 04:31 PM   #14
Art Newland
How did you find this originally? Oil catch basin? What is that? Something you put under the car to catch oil? Then can't imagine it coming out of the engine.
Old 04-15-2017, 04:36 PM   #15
johnneilson
It is never good to have parts coming out of a motor rear, side or otherwise.
That looks too small to be a rear seal piece, just my observation.
Could it be maybe from trans input or clutch shaft?
J
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 04-15-2017, 04:39 PM   #16
bluzrocker
bluzrocker's Avatar
yes a Modle A supplier has them to catch oil and keep it off the floor..located under the bell housing area
Old 04-15-2017, 04:46 PM   #17
bluzrocker
bluzrocker's Avatar
tx for your observation...some also think it's to small for rear main...mystery....but you gave us 2 more possibilities...TX TX
Old 04-15-2017, 04:58 PM   #18
CarlG
CarlG's Avatar
I thought it was a paper plate.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 04-15-2017, 05:01 PM   #19
daveymc29
daveymc29's Avatar
I agree that it appears to be a washer for a garden hose. Have you been doing any cleaning using a hose? I would suspect someone is messing with you or it got kicked up off the road while driving and ended up in that catch tray. We had a fireman bought a new car. He was very proud until someone pointed out an oil leak. He had never seen oil in his driveway, it only happened at the station that it leaked, he said. The question was then asked if he noticed a leak when he went shopping for the station. He did. The culprit was a fireman with a shirt can of oil that even went to the store while he was in shopping and created a little puddle of oil under his car. Someone finally confessed when he was making arrangements to have the car towed to the dealer for inspection.
daveymc29 is offline   Reply With Quote
Old 04-15-2017, 05:16 PM   #20
johnneilson
Sounds like the crew that put gas into the new guys car every week for the first month or so, then took some out every week from then on......
