04-13-2017, 07:21 PM | #1 |
Ford primer
Did Ford use primer under the color coat of paint? Does anybody know what color it was close to? Not that it matters much but when I sand through I was wondering if or what to expect.
04-13-2017, 07:33 PM | #2 |
Re: Ford primer
A dark red oxide.... can be matched with PPG Kondar Red, if still available.
JB |
04-13-2017, 07:39 PM | #3 | |
Re: Ford primer
If this is what you have, it's pretty hard tp remove. Leave as much on as you can.
Good enough.. Isn't. |
04-13-2017, 10:18 PM | #4 |
Re: Ford primer
I believe it was called "Bonderite" and it was a reddish-brown.
04-14-2017, 11:02 AM | #5 |
Re: Ford primer
My Briggs Fordor with original paint got whacked in the upper rear corner in the 1940's, and took a small chunk of paint. The primer along the edges of the gouge is indeed a reddish brown, and slightly translucent, like old epoxy. It is also noticably thick and a little brittle where it has been exposed to sunlight.
Oddly enough, the bare metal spot shows no signs of rusting. Just barely a little surface spotting that easily wipes off with WD-40 on a rag. Perhaps some residue of the primer keeps it from being attacked? |
04-14-2017, 11:14 AM | #6 |
Re: Ford primer
04-14-2017, 11:55 AM | #7 |
Re: Ford primer
04-14-2017, 12:01 PM | #8 |
Re: Ford primer
not sure if you will be able to see the picture but if so this is what i found when i removed the paint on the one i'm working on
Terry |
