Old 04-06-2017, 06:26 PM   #1
Jerry Kzoo
Jerry Kzoo's Avatar
Default Oil Pool in Center chamber
I took my valve cover off to try to fix a pesky oil leak. What I am noticing is that the front and rear chambers have drained out any oil that was sitting in them, but the center area is retaining the oil. should it be draining down into the center main? If the answer is yes, how can I check to make sure there is no obstruction?
The car has set for over a day.
Thanks, Jerry
Jerry Kzoo is offline   Reply With Quote
Old 04-06-2017, 08:21 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Oil Pool in Center chamber
Run a pipe cleaner down the oil tube for the center main. You can feel when it touched the crank, then pull it out and check for sludge.
