Old 03-21-2017, 05:40 PM   #1
gypsycandle
gypsycandle's Avatar
Default Quwstion on the safety switch?
If the safety switch is installed so that the case of the switch touches the frame, does that create a ground and nullify the purpose of the switch?? I know it is a switch in the positive side (which is ground in the Mod A) but if it touches a ground , what happens electrically? Thanks in advance.
gypsycandle is offline   Reply With Quote
Old 03-21-2017, 06:52 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Quwstion on the safety switch?
I would think they all have the case isolated from either terminal, but use an ohm meter to be sure.
Old 03-21-2017, 07:16 PM   #3
hardtimes
hardtimes's Avatar
Mine is fastened to the metal front of the seat riser of my '30 roadster.
There would be no need to have a cable in connection and a cable out connection in the battery ground cable (to frame/engine/or) if the switch , itself, was/is the ground, eh .
AND, the cables colors (red)for positive 'ground' in a stock 6v model a system is different than ground (black) in 12v system.
hardtimes is offline   Reply With Quote
Old 03-22-2017, 09:30 AM   #4
Lona
Lona's Avatar
In other words, the circuitry inside the switch is isolated from the exterior case so having the case touch the frame is not a problem.
Glen
'31 Model A Deluxe Roadster
'35 Packard Convertible Sedan
'88 Pontiac Fiero GT
'36 Auburn Boattail Speedster replica
Lona is offline   Reply With Quote
Old 03-26-2017, 09:13 AM   #5
gypsycandle
Thanks Glen...yes i installed it and it works perfectly.
Old 03-26-2017, 09:15 AM   #6
gypsycandle
Thanks Tom.. you are right... i installed it and it works perfectly.
Old 03-27-2017, 07:51 AM   #7
Bob Bidonde
Bob Bidonde's Avatar
The case is electrically isolated / insulated from the conductor that is switched.
Bob Bidonde
Old 03-27-2017, 07:57 AM   #8
SeaSlugs
SeaSlugs's Avatar
Question about these switches - I plan to mount it in the seat riser, when you guys punched holes in the under the seat pan for the cables did you use grommets or something so the body doesnt cut into the cables?
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 03-27-2017, 12:17 PM   #9
hardtimes
hardtimes's Avatar
No 'punching'..the hole/space was hole by ford ,there to easily place the switch. This was ,as stated, a '30 roadster. You are making/breaking the ground cable ONLY, so no grommet necessary.
Old 03-27-2017, 12:48 PM   #10
Mitch//pa
Only the mounting post of the switch is through the floor on the ones i install... the actual cables and connections to the switch are underneath.
