Old 03-18-2017, 04:41 PM   #1
dave11
Default Horn issue
Have a 30 coupe with a 6 volt generator. When the engine is not running the horn works fine. When the engine is running it also works OK.
Turn on the headlights and the horn barely sounds at all.
Wondering if I should run another wire direct from the battery??
Dave Eddie
dave11 is offline   Reply With Quote
