Old 03-16-2017, 03:55 PM   #1
loubob
Default Speedometer not working
I have an early(4-'30) 1930 standard coupe with a Mitchell o.d.
On the ride home from Newburgh,NY, the speedo stopped working.
Found the Mitchell speedo extension was not working and obtained a new one rom them.
Speedo cable is 3 years old.
Installed new Mitchell cable & connected it to the main cable. Speedo not working.
I disconnected the cables. Ran a drill on the main cable and speedo works fine.
I turned the rear axle and felt the inner Mitchell cable turning as it should.
Reconnected and tried again. Speedo still not working.
Suggestions/thoughts??
Thanks in advance.
Bob
loubob is offline   Reply With Quote
