Old 03-08-2017, 06:11 PM   #1
Cool Hand Lurker
Cool Hand Lurker's Avatar
Default Sleeving one cylinder
Do I have to tear the engine down to the bare block to sleeve just one cylinder? This is a 59A, 3-3/16 bore engine.
Cool Hand Lurker is offline   Reply With Quote
Old 03-08-2017, 07:35 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Sleeving one cylinder
You don't have to, but the bearings won't like you if you don't----you will never get all the boring debris out without total diss
Unless it is a tin sleeve that is being replaced---they were designed with quick in chassis replacement as one of the benefits
Old 03-08-2017, 07:52 PM   #3
Greg58
Greg58's Avatar
I would say yes, back in the late 70's I ran a machine shop for several years, after installing a sleeve I always ran the block through the vat/pressure washing machine to remove all shavings. The process of boring the cylinder as much as .187 or more creates a lot of shavings.
Greg
Greg58 is offline   Reply With Quote
Old 03-09-2017, 06:19 AM   #4
JWL
It depends---if the engine already has sleeves it might be possible.
JWL is offline   Reply With Quote
